Display Port Adapter, Flickering Screen
dylskee
Central MA
I finished my new build (in my sig) and I'm having an annoying problem with an adapter to one of my monitors. I'm running a triple screen setup and they are a Korean X-Star DP2710 LED 2560X1440 resolution. The new cards (running 2 cards) only have a single DVI-I and a few display ports, the monitors only have DVI-I so I had to buy an an adapter to connect to one of the display ports. Now I'm getting a weird screen flicker with lines running across the screen. If I unplug the display port adapter from the card and plug it back in it will be okay for a while but will return. I bought two of these adapters by mistake, I tried both both of them with the same results. In hindsight, I should have just bought a DVI-I to display port cable. Has anyone seen this happen with these adapters?
Here is the adapter: http://www.newegg.com/Product/Produ...D_Active_Adapter_(M/F)-_-12-996-113-_-Product
Here's the cards: http://www.newegg.com/Product/Product.aspx?Item=9SIA1N83U90872
Here's the monitor: http://www.ebay.com/itm/Perfect-Pix...502506?hash=item4ac52ae4aa:g:jPYAAOxygj5SeX6w
  • 20160313_175228_17027052622604.avi
