o0OBruceLeeO0o said:
My monitor (Proview ps909s) is looking odd at certain resolutions. The top corners are about 1/8 inch in than the corners at the bottom, making it curve towards the upper half. It is not a very serious problem, but its very annoying
. My video card is a MSI Ti4200 128mb. If anyone knows a fix for this please tell me. Thanks
Check your manual.
It says you have 4 key OSD (On Screen Display) adjustment.
And heres what you can adjust:
OSD Function ·
. Contrast/Brightness
· H-Pos, V-Pos, H-Size, V-Size
· Pincushion
· Rotation
· Trapezoid
· Parallel
· Unbalance
· OSD Location
· Display Frequency
· Color/Color Temperature – Yes/2
Keep in mind that each resolution will have to be adjusted seperate and you can set it back to the original setting by pressing the reset button.
