Dissappointed in MC-370
OnDborder
Senior Member
HOT 'n Arizona
I must have done something wrong because it seems that I get better cooling with my Alpha 6035 than with the Swiftech MC-370 with the Delta fan and A/S.
MC 49 idle 30case
6035 47 idle 30 case
I know these are higher temps than most of you but I live in Az. and don't want to pay out the nose for power for the AC. I have 4 case fans, 2 in, 2 out not including the PS fan.
So any suggestions would be welcome on what I can do to or maybe on a different HSF.
Thanks
MSI K7T Turbo-R ver.1.0b16
AMD 1gig Tbird @ 1190 axia 140x8.5
384mb cl.2 133 Crucial
2 Maxtor 7200rpm/100 striped
Radeon 64 ver.7089 "Raid-On" tweaker
Alpha 6935, Delta 38cpm
SBLive mp3 5.1
Soho Ethernet card
Win 98se
we have similar setups, cool
anyway. no, i think ur gettin about what you should expect. the 370 is no better than the alpha, the wbk or the thermoengine. it isn't in the same class as the SK6, Glaciator or the 462.
so, ya those are about the numbers you can expect.
also you don't mind the sound of that delta?
Plat (Jun 28, 2001 11:34 p.m.):
So the next step would be to invest in a SK6 or Glaciator? Where's the best place to buy?
