How well does using distilled water protect against system frying in the case of a leak? I know that distilled is much less conductive than regular water, but I also know its not totally un-condutive. We've all seen the experiment in science class where the light blub wires are put in regular water, and the bulb lights up. Then they're put in distilled, and they don't light. But thats in a tank of water with the wires a few inches apart, not on a computer board with traces a few mm apart.
Is it really worth it to put distilled in your system? Will it just fry it anyway if there's a leak?
