- Jan 17, 2017
- North Vancouver
I put a Captain 240ex by Deepcool in my new build 2 months ago. I am totally happy with it and my i7-6800k chip runs at 40c while rendering video (oc at 4200mhz).
But when I went to put in a good review I saw a lot of bad leak reviews. I do a lot of house plumbing and I can't imagine that a factory build/sealed unit would just start leaking after a couple of weeks. Is this common? Are these leakers twisting their hoses in some crazy direction? I certainly wouldn't want to risk coolant running over my gpu.
Also, is there a way you can put in a leak alarm to get early warning, like a moisture sensor where the hoses go into the block?
Any experiences with factory cooling leaking will be much appreciated.
