Conclusion
The Black Knight is made to be very quiet, and it looks elegant. The cost may be disagreeable to some, but I personally think this is a pretty good value for the ~$69.00 that you’ll have to dish out for the Black Knight. If you think about it, buying a fan controller with the temperature readout would run you about $30 or more. So that leaves about $40 for the case itself, which isn’t really that bad considering this case has pre-made 120mm fan holes. Another problem with this case is the sliding door; it makes more noise than it should. If you are into wire hiding and like to run most of the wires on the back of the mobo tray; good luck, because there’s very little clearance between the tray and the side panel. Overall, I am pretty pleased with the Ahanix Black Knight case.
