- Jan 10, 2009
Hi all,
So finally after much research, this will be my next upgrade:
1 x Heatkiller IV basic acetal
1 x Heatkiller GPU block for gtx 1070 or 1080
1 x Aquacomputer AMS 480 rad
1x Aquacomputer Radical 4 - 480 rad
3 pairs of Koolance QD4's
Tygon R6016 Norprene tubing
Coolant = Innovatek Protect
I have one D5 with EK top + res. Loop plan: Pump(s) -- cpu -- gpu -- 480 rad --- 480 rad --- pump(s) is this the correct loop or should i change the loop order?
Judging from reviews the AMS rad is rather restrictive the Radical rad is low/medium restriction.
The heatkiller IV basic Acetal is one of the least restrictive blocks out there.
So would one D5 pump handle this loop with good flow atleast 1gpm? Or should i get my self another D5 pump and combine them with EK top for 2 D5's in serial for more head pressure?
I went with the Aquacomputer rads because they are clean inside no flux that may end up in my blocks as a side note i think two 480 rads should be good for a cpu and gpu loop while getting good temps as well as silence. And Norprene tubing for no plasticizer issues or leeching just want a clean system.
Some reviews compared the AMS rad with the radical rad and the AMS won the radical 2 was much thiner then the AMS the Radical have in my list is the radical 4 which is even thicker then a monsta rad.
Anyway your feedback regarding one or 2 D5 pump(s) is much appreciated
