Do my temps look nornal to you?
Taller51169
So, after my 6 month maintenance i got that WC worm again which got me curious. What bothers me every now and then is that on the net there are several posts with similar systems and less cooling which somehow achieve better overall temperatures than me. This got me thinking if im doing anything wrong.
I currently running 120 x8 RAD all in 1 big loop with 2x Swiftech 655 Pumps. The Pumps are added to the loop through the Koolance RP-450x2. All my fans are Scythe Gentle Typhoon AP 15. My temps are: (Ambient temp around 26C)
Cpu @ Idle 36 C Socket, 26 C Cores
Cpu @ Max Load ( 1 Hour OCCT, 12 hours Prime) 56 C Socket, 47 C Cores
Gpu 1 @ Idle 36 C
Gpu 1 @ Max Load (1 Hour Furmark) 58 C
Gpu 2 @ Idle 38 C
Gpu 2@ Max Load 64 C
Now others claim that they have better temps with 120 x 5 RAD surface or even 120 x 3 which is not possible ofc. What i would like to ask is if these temps seems ok to you guys or if i should expect better results from my cooling system? Any opinion is appreciated.
On my loop I see load temps in the 50's to low 60's after several hours of Prime95 and they will drop to 30's-40's almost immediately when I take the load off the CPU.... So, ya your temps look fine and normal.
AMD != intel
I don't understand you people, my GPU idles around 56C, and under load is around in the 70-80s. Though that's probably cus my computer is stuck under a desk with bad ventilation. :p
My temps are on the safe range i know:). Thing is, maybe i should have even lower considering im running 120.8 rad. In other words i think that my WC underperforms a bit. Btw i also checked that excel thingy from martinslab were it calculates you dt based on your setup and according to it i should have a dt of about 7. Doesnt seem like it...
