DarkFire55 (Jun 25, 2001 08:06 a.m.):
I think that both will generate the same amount of heat.
However i think the 1.2-1.4 will dissipate the heat better than 1.0-1.4 because the 1.2 chip contains more transistors.
Meaning you have to work harder to pump the same amount of heat from the 1.0 chip.
I think that sounds right.
Anyone out there know if this is true or not?
