Your goals are very high but if there is a mobo out there that can do it then the iwill is your man! click the hyperlink in my sig with the cpu and it will take you to the cpu databse adn you can check for yourself.
The IWILL is going to be the board that will most likely get you to your goal. Just be sure to have plenty of CPU cooling and you have a good chance with a 1.33.
man you got one sweet chip or the glaciator really rocks! I just ordered a gladiator adn I hope it does okay if not I will use it on a old p3@800. what other hsf did you try?
Hey el i noticed you got a voodoo 5500 ,
I think i might buy one for 100 bucks used. but im not sure yet
What games are you having trouble with on this card. people with the geforce cards are saying "your card will suck with new games"!
