does anyone know how to make a Vcore & Vmem mod on a Hercules Geforce 2 PRO ?
mcrapid
I've searched on the net, but found no guide for the modding of this card...
that would be most cool if someone gave me a link for this!
thx in advance
hello mcrapid, welcome to the forums!
both GPU and memory on a GTS are supplied by the same regulator as I recall, but I could be wrong. Regardless, it should be the exact same as any other volt-mod- find the regulator for the V you want to adjust, and hook in a potentiometer between the power source and input leg of the regulator. OR use a single-value resistor instead.
Haven't seen any links explaining it, but you can figure it out for yourself if you have the right tools I bet!
Just make sure you have adequate cooling- a vmod will definately increase heat production by a lot.
Link to a Geforce 3 volt mod
thanks for the welcome :) , rare enough to be mentioned !
maybe u are right about the regulator model , but I've also seen video cards from other manufacturer's that needed 2 resisors instead of 1... so if somebody has already done the mod on this card, additionnal precisions would be welcome !
(thx for the link 2!)
huh, 2 resistors, I haven't seen that. I'm all curious now!:)
Maybe 1 resistor for gpuVcore, and 1 for memVcore?
I'll keep my eyes open for a link for ya- I haven't done a voltmod since my Voodoo3, I'm kinda rusty:)
ok, i understood what was said in the article (at last), and the the chip used on the ASUS V7700 is the same, but I can't see to which precise pins they connected the resistors...
if anyone has a picture of better quality, that would be really helpfull !
