Does anyone know what this is? CPU/host/pci/spreadspec?
Karl04
Suffolk, VA, USA
I found this in the bios screen under voltage control
CPU Host/PCI/Sread Spec
here are the things that were in that menu
default
100/33mhz/-.5%
100/33mhz/off
100/33mhz/+ - .5%
etc. is that front side bus? or what?
Karl
Yes the Host is the FSB, and you should probably leave the spread spectrum turned off if you are overclocking. It is my understanding that your computer will be more stable with it turned off.
Absolutley correct. The Host clock should not be trying all sorts of fancy things on its own by changing the frequencies slightly, you clock it, you control it with your settings which are stable frequencies.
However you will want to see how your ram behaves, it may want to run at hclk (hclk = host clock, the same speed of the processor) but play with it, find its limit which will likely be indicated by the system freezing, not booting, or blue screening.
Don't forget that turbo setting though, it just may help as well.
