- Nov 8, 2002
- Western Michigan University
Its from CPUFX but i don't want to get it from there, and just want to know if theres anything else that can take the temp of the water like this? Thanks.
DorrellCO said:I set one up once by just buying the indoor/outdoor probe for $10 at Wall-Mart and a T from Home Depot for $1.50 and some silicone. Take the cover off the inline probe for the outdoor part (little black piece with sticky tape on it) stick it in the T to where the probe will barely touch the water as it flows and then fill the rest of the hole in the T with silicone. Let dry over night and you are good to go. I like the indoor/outdoor because you can get the water temp from the outdoor probe and the room temp from the indoor probe all in one unit.
Can O' Beans said:The digital therm that Radio Shack sells might work as well.
I know Home Depot sells various sizes of the poly Ts
Stalka said:cant ya just use a CompuNurse?
