Does CPU temp effect FSB overclocking
wuzzapiman
I am wondering y i can only get 173x12..is it CPU cooling cuz its idling @ around 42C
2400+ AIUCB "9"
Abit AT7-MAX2
Corsair XMS plat. 512Mb CAS2 PC3200 bla bla bla
maxima88
Heat can most certainly affect your o/c. The lower your temps, the higher you can o/c. Looks like your cpu temp is high based on your idle temp. What HSF are you using?
Goo Kenson
It's either voltage or just the chips limit...With that in mind, try lowering the mult to raise fsb more and see if you can go higher. Also try raising vcore.
W
wuzzapiman
The CPU runs fine @ 1.9 V and 14x166
Some cheap coolermaster cooler...temparay...geting pump tomarrow
