- Jan 8, 2002
- Boulder CO
I have heard that running at 1.85 or above volts for CPU's effect the life of the processor.... is this true?
I dont see why it would be true and if it is i dont see how it makes any sence at all.... if you have a rig with a 80mm heatsink like a alpha or swiftech, and run at say.... 1.95v, then you will probably get temps in high 40's to mid 50's. However, these temps are still very low compared to the stuff that you get to with the stock cooler that comes with the retail chip.... if AMD guarantees that using the stock cooler on a XP, at 1.75 v, you CPU will last 3 years (isnt that how long the warrenty is?) and you get temps with the stock cooler in the high 50's to early 60's, then why would running at high voltages affect the cpu? it does not make any sence to me... can somebody explain this a little better?
