- Oct 18, 2002
- Los Angeles
I'm trying to get speedfan to tie two of my case fans that blow directly on my graphics cards to the gpu temp... but I can't seem to control fan speed through speedfan, is there some special way to disable UEFI bios fan control to enable speedfan? Or does speedfan not work for z170 asus mobos?
EDIT: TO ANYONE THAT HAS THIS PROBLEM, I FOUND THE REASON. If you are running asus AI suite speedfan will not work, you must first close speedfan, then close asus AI suite, then re-open speed fan, and then you can adjust the PWM mode to "manual" in the configure -> advanced section in speedfan.
