wannaoc said:
This is one I have been looking at because I need similar to you. I haven't had much feedback about it except 2 people talking about the company but it doesn't seem bad to me. Heres the link...http://www.sysfx.net/cgi-bin/cart.e...&sub=Heat Exchangers&pro=Radiators&sku=EX-430
man that looks awesome but $65???? i got my heatercore @ napa for like $12! shop discount but still, that's a huge difference. i have a friend @ napa so not only do i get a discount, i was able to go in the back and dig through boxes till i found a heatercore about the size i wanted. sometimes they may let you do this at any parts store if you ask very very nicely. lol. myheatercore is fairly huge though, i wanted the largest i could fit, i'll say it's about 6x7 1/2". works well, a bit too small for 2 120's though, and a bit too large for 2 80's. i've got one 120 mounted on it, pulling air up out of the case and through it, works very well so long as i keep the case temps low enough.
my point is, if you look hard enough, you can find a heatercore to fit your size requierments without spending alot of jack!
good luck!
J.
