I just got a giga-byte 7vax and notice that it uses the AMD xp built in diode to read temps. Does the chip diode read temp higher then normal? If yes how much higher. My 1600+ runs fine @166 or 1754mhz but I need to up the voltage to 1.88ish to make it stable. At that voltage temps are 50c idle up from 42c stock. So is a 50c idle too high? thanks
