R
robjustice
Guest
I got a T-Bird 1.2 axia-and set it up for water cooling. I used the following. An amaze2 block, a coolcube w/ a 120mm-69cfm fan, an eletrical junction box(for a reservior) and a Eheim 1048. I used all 3/8 inner dia hose, distilled water-with water wetter, I filled the system and let it run under water to insure that no air was in the system. I used artic silver between the block and cpu. The block is mounted on springs-which are run down pretty tight. My system is at 1500/1.85volts-and my temps are around 44to45 degrees. Ideas?
