Does this work together?
karl472001
I believe I am finished pricing out a computer and I am pretty sure everything would work fine together. However, I want to double check ask people here to check and make sure if it will all work.
__________________
1 ANTEC Performance Plus Case with 430W Power Supply, Model "PLUS1080AMG" -RETAIL
1 NEC 8X Black Dual Layer DVD+/-RW Drive, Model ND-2510A BLK, OEM BULK
1 Seagate 120GB 7200RPM IDE Hard Drive, Model ST3120026A, OEM
2 Kingston 184 Pin 512MB DDR PC-3200 - Retail
1 ViewSonic E90B 19" CRT Monitor -RETAIL
1 Intel "D865PERLL" i865PE Chipset Motherboard for Intel Socket 478 CPU -RETAIL
1 Intel Pentium 4/ 3.0E GHz 800MHz FSB, 1MB L2 Cache, Hyper Threading Technology - Retail
1 Albatron nVIDIA GeForce FX5700 Video Card, 256MB DDR, 128-bit, DVI/TV-Out, 8X AGP, Model "FX5700Q" -RETAIL
__________________
Thanks,
Karl
nissmo300
I suggest getting the Intel 3.0C - almost the same as E with less heat. Also I suggest not buying an Intel MB if you're looking to OC. They hardly have any OC options (maybe it'll allow a 4% OC the most which is not much) but if you're planing not to OC its a very stable board.
