Kryten (May 23, 2001 04:22 a.m.):
I've maxed the board at 1.95 volts and I have 1.123 GHz how much more could I expect from make a voltage mod?
Aman99 (May 22, 2001 12:59 a.m.):
I was wondering, any of you that have voltage modded your motherboards, how much overclocking improvement did it give you?
Aaron
Hoot (May 23, 2001 01:00 p.m.):
As long as you adequately cool the chip, by the time electromigration takes its toll, you won't want the chip anymore anyway. There's the issue of toll on your PSU also. Above 2.0V, with a Tbird, you should be running a 350 or 400W unit. Tbirds guzzle power above about 1.95Vcore. All CPUs have a sweet zone for speed and core voltage. Once you get outside the sweet zone, it takes a disproportionate increase in core voltage to get a misorly increase in speed. IE, my 1.0G/266 will run 10x145 2-2-2 at 1.75V (top of the sweet zone), but to get it solid at 10.5x145, it takes 2.00V.
Hoot
use a pod so u can adjust the ohm`s.Aman99 (May 23, 2001 11:33 p.m.):
Hoot
So if I use a Swiftech MC462, and an Enermax 431 W PSU, then it is probably a safe thing to do? Also, to do the mod, tomshardware recommends a 24 K ohm resistor at 1/4W rating, is it ok to use a 22 K ohm resistor at 1/4 W rating?
Aaron
THANKS FOR ALL REPLIES SO FAR!
Colin (May 24, 2001 12:58 a.m.):
Aaron,
What motherboard do you have?
