Dolk, Please help
I have a very good watercooling system (DTek Fuzion CPU Cooler, Asetek 1000l/hr pump, and Thermalchill 3X120mm radiator in custom box). It might not be the best these days but its still pretty good. Anyways, I bought a Phenom II 940 because I heard that they are easy to overclock if you have very good air cooling or pretty good water cooling. So, I tried my hand at overclocking and 3.2, 3.4, and 3.6 Ghz came easy with no need for an increase in core voltage. With 3.8 Ghz, I could not boot into Windows at stock CPU volts, so I raised it to 1.40V and ran several benchmarks (Entire
3dMark series and ran OCCT for 10 minutes). No crashes, stellar performance. Then after about 1 hour more with the wife using the computer, she reports of a BSOD. Raised CPU volts to 1.45V and everything was fine. Wife again found a BSOD after about 1 hour. Raised CPU volts to 1.50V with the same result. Then I read your overclock guide. Very good information. I again tried with the CPU-NB running at 2600Mhz CPU-NB volts at 1.30V, CPU volts at 1.53V. Same result. BSOD after about 1 hour. No instability indicated before then even with stability tests and benchmarks. My CPU temperature stays below 40 degrees C the whole time. Do I just need to be brave and push the CPU volts further? I am just looking for help in achieving stability at 3.8Ghz. Thanks.
