*********************** Log Started 2016-03-13T22:58:29Z ***********************
22:58:31:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
22:58:32:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:00:20:WARNING:WU01:FS01:Failed to send results, will try again later
23:00:21:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:00:23:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:02:11:WARNING:WU01:FS01:Failed to send results, will try again later
23:02:12:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:02:13:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:04:00:WARNING:WU01:FS01:Failed to send results, will try again later
23:04:02:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:04:03:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:05:51:WARNING:WU01:FS01:Failed to send results, will try again later
23:06:39:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:06:40:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:08:31:WARNING:WU01:FS01:Failed to send results, will try again later
23:10:56:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:10:57:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:12:45:WARNING:WU01:FS01:Failed to send results, will try again later
23:17:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:17:46:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:19:36:WARNING:WU01:FS01:Failed to send results, will try again later
23:28:50:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:28:52:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:30:40:WARNING:WU01:FS01:Failed to send results, will try again later
23:46:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:46:48:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:48:37:WARNING:WU01:FS01:Failed to send results, will try again later
00:15:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:15:50:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
00:17:43:WARNING:WU01:FS01:Failed to send results, will try again later
01:02:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
01:02:49:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
01:04:43:WARNING:WU01:FS01:Failed to send results, will try again later
02:18:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:18:50:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
02:20:44:WARNING:WU01:FS01:Failed to send results, will try again later
04:21:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:21:50:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
04:23:44:WARNING:WU01:FS01:Failed to send results, will try again later
******************************* Date: 2016-03-14 *******************************
07:40:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:40:50:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
07:42:41:WARNING:WU01:FS01:Failed to send results, will try again later
08:19:32:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:19:34:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
08:21:52:WARNING:WU01:FS01:Failed to send results, will try again later
08:21:53:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:21:55:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
08:23:41:WARNING:WU01:FS01:Failed to send results, will try again later
08:24:30:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:24:32:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
08:26:17:WARNING:WU01:FS01:Failed to send results, will try again later
08:28:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:28:46:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
08:30:31:WARNING:WU01:FS01:Failed to send results, will try again later
08:35:36:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:35:37:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
08:37:24:WARNING:WU01:FS01:Failed to send results, will try again later
08:46:42:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:46:43:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
08:48:29:WARNING:WU01:FS01:Failed to send results, will try again later
09:04:38:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:04:40:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
09:06:26:WARNING:WU01:FS01:Failed to send results, will try again later
09:33:41:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:33:42:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
09:35:30:WARNING:WU01:FS01:Failed to send results, will try again later
10:20:39:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:20:41:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
10:22:28:WARNING:WU01:FS01:Failed to send results, will try again later
11:36:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
11:36:41:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
11:38:34:WARNING:WU01:FS01:Failed to send results, will try again later
13:39:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:39:41:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
13:41:25:WARNING:WU01:FS01:Failed to send results, will try again later
16:58:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
16:58:42:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
17:00:28:WARNING:WU01:FS01:Failed to send results, will try again later
22:20:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
22:20:42:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
22:22:31:WARNING:WU01:FS01:Failed to send results, will try again later
******************************* Date: 2016-03-15 *******************************
04:20:41:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:20:42:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
04:22:34:WARNING:WU01:FS01:Failed to send results, will try again later
06:50:15:WU03:FS01:0x18:WARNING:Console control signal 1 on PID 3804
06:50:15:WU00:FS00:0x21:WARNING:Console control signal 1 on PID 844
06:58:19:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
06:58:20:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
07:00:15:WARNING:WU01:FS01:Failed to send results, will try again later
07:00:16:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:00:18:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
07:02:01:WARNING:WU01:FS01:Failed to send results, will try again later
07:02:54:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:02:55:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
07:04:38:WARNING:WU01:FS01:Failed to send results, will try again later
07:07:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:07:09:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
07:08:52:WARNING:WU01:FS01:Failed to send results, will try again later
07:14:02:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:14:23:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
07:15:37:ERROR:WU01:FS01:Exception: Transfer failed
07:25:05:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:25:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
07:26:52:WARNING:WU01:FS01:Failed to send results, will try again later
07:43:02:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:43:03:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
07:44:48:WARNING:WU01:FS01:Failed to send results, will try again later
08:12:04:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:12:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
08:13:50:WARNING:WU01:FS01:Failed to send results, will try again later
08:59:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:59:04:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
09:00:49:WARNING:WU01:FS01:Failed to send results, will try again later
10:15:04:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:15:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
10:16:50:WARNING:WU01:FS01:Failed to send results, will try again later
12:18:03:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:18:04:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
12:19:50:WARNING:WU01:FS01:Failed to send results, will try again later
15:37:04:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
15:37:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
15:38:51:WARNING:WU01:FS01:Failed to send results, will try again later
20:59:04:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:59:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:00:52:WARNING:WU01:FS01:Failed to send results, will try again later
