- Oct 2, 2001
- San Jose, California
DOS command for NT4.0 setup!! PART2
I'm trying to set up a NT4.0 Server. I've done this many times on this particular server but for some reason this time the floppy disk setup is not working.
I was told to try using a win98 boot disk in order to see the scsi cdrom. This did work but I can not get the cd to start the setup!
I've tried these dos commands at the d:\ prompt [run], [setup], [setup.exe], [start], [startup]. If I type d:\dir I get a list of stuff so I know I can see the cdrom but maybe not the NT4.0 disk.
I do not know anymore dos command.
I used fdisk to make the partitions and set active, as usual. I did not fromat cause I wanted NTFS. (maybe I'll try to format through fdisk and see if that helps)
Any help would be greatly appreciated as usual.
Doug
Doug
