Double boot problem
tainice
Carbondale, IL
ok, so i install 98s and W2kpro on seperate HDs, and then i got this problem, i cannot play my DiabloII- LoD with W2k! what gives? i tried 98s, fine, not problem at all? or i should simply down some some patch in order to play it?
Check out the website - see if they mention Win2k incompatibility problems. Have you got the latest drivers/DirectX?
it is a very fine point, but i have already checked, it is XP, 2000 compatible, and I AM the administrator:rolleyes:
Are you trying to play LoD from the 98 installation folder? If you haven't install a seperate LoD onto the Win2K Partition. The Win 98 LoD will use system files from the Windows registry etc.
Yodums
