Auto Dialup and Win2K
Here is a cut and paste job on how to setup Win2K to autodial. I had posted this in the FAQ thread but it is getting pretty long and kind of hard to read through so I'll post it here. I'm presently not running any rigs on Win 9x, so someone else will have to help you with it that has more recent experience with 9x, but I do remember that it was easier to set up than 2K.
Here is the way to set up Win2K:
Q: How do I enable Win2K to automatically dial up and send and receive WU's?
A: Look in the Win2k help files in the index and look up dialup connections and under it there is an entry for automating. Click on it and in the right hand pane is a link to autodial, click on it. It then shows a couple of links to configure autodial and to start the remote access auto connection manager. You will have to go into both of them and follow the steps, which are fairly easy. While you are in the RAACM, configure it to start the service automatically as it set set on manual by default. After you've done this it will be configured and close out the help files.
The first time that it goes to connect after starting the remote access auto connection manager and enabling auto dialup, it will ask if you want to connect. Then, it will ask you which connection to use, even if you only have 1 dialup account on the computer. Then it will ask if you want to be asked all this again before dialing the next time. Be sure to tell it not to ask again or the next time it finishes a WU, it will come up with this same dialogue again. Also, be sure to set the dialup to automatically disconnect after 5-10 minutes instead of relying on your ISP to knock you off for inactivity.
Now enable your autodial and fold on!!
