- Feb 12, 2001
- Fayetteville, AR
i got good airflow but was wondering if i cut a hole in the top of the PS, then another one in the metal part of the case directly above it but leave the plastic outer case intact would that helps get rid of more heat-i already got a fan on the bottom of the PS blowing up through and out the back, or would putting a hole along with a fan in the plastic outer case above the LS be better
Setup is GORB w/fan in it, 1 90mm blowing up and out the rear of the PS, another 90mm mounted in the rear sucking from the back of the processor, 1 120mm in the bottom front blowing in-dont know temps cant check-mobo sux, and MBM wont work, but air feels bout room temp
