dremel vs. dremel - watercooling mods
weapon
USA
I recently burned up another dremel (the handheld model) so I promptly hauled arse up to the local hardware store to buy another one of the variable speed models. When I got there, I noticed a new version of the Dremel Advantage Rotary Saw kit that included a router attachment and the flex-shaft extension.
hmmm...it was a bit more money ($89) but it looked a little more heavy-duty. A quick side-by-side spec check produced an interesting discovery - the regular dremels (like the 395 model) have a 1.15amp motor where the Dremel Advantage rotary saw has a 4.5 amp motor - sold.
I got back to the house and quickly assembled it for a test run on a new waterblock base plate I was cutting out of C110 copper. No comparison - this sucker has one helluva lot more power than the regular models -- well worth the extra $$.
With the flex-shaft attached, it uses the same bits as the rest of the dremel line so more power to all of them. :)
