- Jan 10, 2012
I am using this case, see the little circuit boards behind the drive bays?
you plug a molex and sata cable into them they have a neat little light and you can plug a fan or another little light into them.
I have no idea on earth what they do, when I see them I only see a future failure point, another connection to go bad and having to use molex connectors not sata power cables.
I have owned this case for a few years and all those things work.
this case is getting a monster working rig put in it and the less garbage in it to start out with the better.
this case will be filled with ssd's in all the bays.
what do those little boards do?
can I just take the things out?
do they offer some kind of protection?
