Drivers off of XP pro CD??
DDR-PIII
Disabled
6p6
Where are they on the XP Pro home CD ? and can I use them on windows 98se ? If so how can I get them to work in 98se ? I need the drivers for my AC 97 sound card and XP gots the m:)
thanks
Big Nuttz
Always one step ahead of jdmcnudgent
Toledo, Ohio
I would just go to the manufactures website and download the drivers. I'm 99% sure you cant use XP drivers and have them work in 98SE.
David
Forums Super Moderator
thanks
I'm sure 98se supports the AC 97 sound card. You should have got a driver disk w/ your card/board. Or you can download the drivers.
minoukat
Ottawa, Ontario
If I'm not mistaken, it's in the CAB files for Setup. So you'll have a hard time searching them around ! That's how I remember it, I'm not sure though
David
XP uses a Hardware Abstraction Layer - 98SE uses the hardware directly. Drivers are not compatible.
cw823
Honeybadger Moderator
Earth
www.windowsupdate.com has those drivers....should be listed at the bottom after you run it. At least it always has on EVERY board i've tried with onboard sound. Or go to mfgr. website.....
And 99% about those XP drivers....check that to 100% not gonna work.
Barryng
What is the "Hardware Abstraction Layer" that XP uses as compared to 98SE using the hardware directly?
An answer to this will probably explain why so much hardware and software that worked with 98 will not now work with XP.
