My cpu was running at 128f and mobo at94f. My case inccluded a mobo tray. I found 60mm thin turbo fans at PCNUT.COM. I cut 2 holes in the mobo tray. I directly behind the CPU and on a inch under and to the left. then cut 60mm blow holes in the door behind the fan holes. Both fans blowing in. I caould not belive the diff in the temps. my cpu dropped to 108 and mobo to 84. If you have the room give this a try, It really works.
