- Jan 12, 2001
- Knoxville,Tn
This is how I keep el cheapo homemade dryer filter from being sucked into my 120mm Sunon fan. Mine is installed in a blowhole I cut into the front of my case, but you could just tuck the tabs through a fan guard instead of installing inside the blow hole. I'll post pictures as soon as I get some film then develop it. In other words September. 8)
BTW use your own dimensions. These are the sizes I used to fit my blow hole. Just find the right sized cup or any suitable cylinder and add some kind of "Nibs" to hold the sheet.
