- Mar 8, 2002
- Rio de Janeiro - Brazil
Does anybody know how many watts this rad can handle ?
Thx []´s
Thx []´s
Overbrazil said:Does anybody know how many watts this rad can handle ?
Thx []´s
All the cores at dtek ARE THE SAME!!! The pro is just painted and has chrome barbs, the silver one is just painted otherwise, same thing.FIZZ3 said:
The 'regular' core or the 'pro'? The Pro is advertised as being better. They seem to provide for a single 120mm fan only though. Does anyone actually know the actual heatercore models DTek uses here?
With those warm ambient temps I think you would be better off with an inline pump. Can yours be run inline? Running yours submersed will take all 30W and put it into the system where if it was inline only a fraction of the heat would transfer to the water. Yes, i think you should remove the turbulators from the TC-4. The springs should work well for you.Overbrazil said:Thanks safemode, here in Brazil is very hot ( 40 C ) not in my room, but i think it is 32-34 C![]()
Should this 530 gph pump (30 W) too much ??
I know tha maskedgeek runs his maxijet 1200 inline, you should PM him for details!Overbrazil said:Thank you friend, but my pump cant run inline(pic). Here does not have eheim or via aqua, just maxi jet. The maxi jet can run in-line ?
