- Sep 14, 2004
- Land of the What?
- Thread Starter
- #41
ok, the only reason i thought of it that way was b/c if my computer is off my room stays cool, but when im gaming it gets a bit warmer in my room.
HungLo said:I wouldn't get the MCW50... even tho I bought one! You want to keep any Alu out of your loop, who need corrosion? Just get the Acetel/Delrin topped GPU block from DangerDen.
Good pump choice, moddable for more flow in the future. It's barbs are 3/8" tho, so an adapter or 3/8" into 1/2" tubing is needed.
Stay away from Thermaltake stuff!!! The Waterplant one looks better.
Looking good.
cetoole said:Actually, I believe the Dangerden GPU waterblock being referred to, which is the one I recommend, is the $45 Maze4 GPU with acetal top. Instead of using adapters for the DDC pump, just put some 3/8"ID 1/2"OD tubing over the barbs on the pump, and stretch your 1/2" ID tubing over that, and clamp it down. I am doing something similar in my system, but with 7/16"ID tubing instead of 1/2"ID tubing. It saves the money on adapters, looks cleaner, and should have less restriction. Also, you can save some money by using a T line instead of a res.
I am currently using that setup in my loop, and have no problems at all. The MCP350 is much quieter than the 650, but lower flow. There is a mod that helps the flow for the 350, but it voids your warranty, and makes the pump a lot larger. I would do the mod if I could get a replacement top for my pump so if I mess it up, the pump is not ruined. If you decide not to get the MCP 350, I would go for the AquaXtreme 50z instead of the MCP 650.honhon said:oh, ok, i was thinking of another GPU block then, ty, and ill look into that tube idea, how much better is that one pump than the other? i know the 350 uses less power, and i really like its design, you'll have to keep me posted on how that tubing idea works.
cetoole said:I am currently using that setup in my loop, and have no problems at all. The MCP350 is much quieter than the 650, but lower flow. There is a mod that helps the flow for the 350, but it voids your warranty, and makes the pump a lot larger. I would do the mod if I could get a replacement top for my pump so if I mess it up, the pump is not ruined. If you decide not to get the MCP 350, I would go for the AquaXtreme 50z instead of the MCP 650.
cetoole said:Weapon Core all the way, also get one of his shrouds.
