HI all, would any of you be so kind as to read this post and offer a way forward for me?
I have two Philiips BDM4065uc (40 inch 4k monitors).
I am about to have a pc built to run them from this one PC.
At the moment , my friend and I are trying to decide upon the best specification to run these together, smoothly without any issues!
As such, these following questions have occured to us.
1)Solution 1 might be to choose a gpraphics card that supports two or more DP ( display ports). ( This is assuming that the maximum pixel area is per monitor and not total area for all ports together.
2) Soltion 2 might be ( given that solution one is not practical or even too costly compared to a better solution)
two graphics cards installed on the same motherboard, each running one of the monitors.
I think from past ecperience, i would like the cards to be of gaming standard.
background and context.
we have so far identified as a possible CPU the i7-5820K (6 core haswell)
this is because the use of the pc will be more suited to multithreading, multimedia applications, rather than single threading.
Motherboard: Asus X99-A/USB 3.1 Socket 2011-v3
this motherbaord i think supports more than one graphics card .
Ram so far identified as appropriate is :
HyperX Savage Black 8GB DDR4 2666MHz Memory
I would really appreciate any guidance that can be offered, on this, as well as any other suggestions for componentry to complete the strong pc build.
All the best,
Bingo
All the best,
Bingo
