Dual boot 2 single?
verbatim
Western Australia Perth
Howdy. First off I cant program s**t but I have del my win 98 drive and now want to boot straight to win xp. I read somewhere that the file to change is boot.ini.
Is this true?
My currant boot.ini reads:\
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /fastdetect 1
C:\="Microsoft Windows"
What will I change to get a single boot system?
If I mess up can I just use restore to earlier point in win xp?
Ta
deRusett
Midland, Ontario
Remove the 1 after fastdetect
and remove the line C:\="Microsoft Windows"
this should make it work
you might have to change the
partition(2) in both lines to partition(1) but I don't think that will be needed
Captain U
lakewood n.j.
I had the same problem with win98se and win 2k I'll see if I can find the printout of how to help, I think I lost it though,
also I don't know if this will work because I wanted 98se not 2k but here goes nothing.
I remember that you had to cut C:\="Microsoft Windows" and paste it all the way at the top of the file right above [boot loader]
after that it should automatically boot into windowsXP and you can deleat all the windows 98 files.
Captain U
lakewood n.j.
what you culd do is format the drive and there is a way to clear the mainboard record I think it's "a:/fdisk/ mbr" find out forshore I know there is something like that.
