Dual Boot Win98SE & WinXP?
13rian
i'm not exactly sure if this is what it's called but basically i want it setup so that i have XP running the main show and 98SE in the back to compensate for compatability with certain programs that are not able to run under XP.
[Note: a saw somebodies who had this type of setup where it was in WinXP and was able ro run MS DOS Promt! :eek: ]
if anyone has the steps for me to follow, thanks a bunch!
if something like this was already posted my apologies [but i DID try using the "search" feature]
Big Nuttz
Always one step ahead of jdmcnudgent
Toledo, Ohio
I installed 98 and then from in 98 I ran setup on XP. During setup you just choose the partion you want for XP. I use a 8GB for 98 and a 8.5GB for XP.
