- Aug 5, 2002
Ok... my primary monitor I've had for now 8+ years is failing. Its probably a cap issue but I've been wanting to get a pair of matching monitors for a while now. So let the hunt being.
But I have an issue. My desk ideally I'd like it set under the hutch, which is a concern. Its roughly 15" tall, and 16" deep so having something that fits in that space is ideal otherwise going to have 1/2 my desk space lost behind the monitors.
So what I'm looking for what it looks like is a dual monitor stand + 2 monitors that are hopefully in the 23-24" screen range with 1920x1080 screen res. Ideally a 3D capability monitor would be sweet but think that will be too pricey for me.
For a stand was looking at this one, seems good and looks like it gives me good range for height adjustment. As well not some huge base taking up a large portion of the desk as I have seen.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824995006
Though monitors im still out on some just have height dim's on it with its default stand which puts it out of my range. Curious if anyone else has a setup currently or some monitors currently that sit below the 15" requirement I have or have stands that can adjust that low with the default monitor.
For the monitors, if they could be HDMI or Display Port would be GREAT, though if DVI thats cool too. I just need to pick up some longer cables.
