With a GeForce 4 MX440 with DUAL VGA using the Nview software and the DualView display mode with 2 monitors, how independently will the two desktops operate? Will I be able to play a full screen game on one (this game freezes if I try alt+tab or ctrl+esc to get to the desktop) and have my desktop with like ICQ and web browing on the other? If I maximize a window on one will it cover both or just that one monitor? Can it be set up so a key combo switches my mouse between each monitor instead of just wraping over? Would this slow my computer down in any way?
I asked a friend and his answers were:
"1. If you tell windows to expand desktop then you will have additional room to put apps. If not it will only mirror the two.
2. If you have a full screen game, you can have open windows on the other monitor, but you you wont be able to use it, if you do it will minimize the full screengame."
So answer 1 is what I expected, but on answer 2... Can anyone confirm or deny that? I'm hoping deny cause thats one of the main 'selling' points I was looking for. Is there a way to get aroudn the number 2? Like to be able to run a full screen game on one monitor and use apps on the other? Maybe if I had 2 vid cards instead of a dual VGA? If there's a way please tell me.
Thx
Thx
