Dual PSU How-Tos
stool
Senior Member
Albany, NY
As the question of hooking up dual PSUs comes up quite frequently in the forum, I have gathered a few links that show some differing methods of accomplishing the same thing.
To use a relay, try Speedy3d's method . It also includes a wiring method.
To hook up two AT PSUs check out Procooling's article.
My personal favorite, which doesn't involve cutting your PSUs wiring, is found at Burning Issues
One I have found is here;
http://www.picard.demon.co.uk/atx.htm
Here's a new one another forum member found at Procooling
IFMU
The Xtreme Senior Nobody
Excellent. Thanks for the links there. Ive seen them all before but have lost them all great to have them somewhere all together I can find what Im looking for.
Question. Would doing that last mod make the psu's capable of supporting dual board?
Im interested in trying to save some dough so I can get a little better CPU's or even some extra ram. So can I do this and be able to use 2 of my present PSU's and use it as one on the motherboard? Would this support it ok?
aulddm
Aberdeen, Scotland, UK
This is what i have been trying to find info on, no such luck yet.
I want to take approx 6 MB and run them from say 4 PSU, seeing as each PSU separately is not under full load, no cd-rom, floppy drive, etc. bare bones number cruching machines (may even go completely diskless). Does anybody have anything on this approach???????
cheers,
Dave
RoadWarrior
Senior Member
Niagara Falls, Ontario, Canada
Damn, now I am more confused. I want to have a second PSU in parallel with my first to stabilise the 5v line under load. Now the procooling article which is the only one which actually deals with issues other than just getting the second supply to turn on, says to isolate the cases of the PSUs from ground for Parallel or Serial use, then it tells you to connect the two grounds together when you wire it for parallel. Now I understand totally about isolating the cases for serila use, but for parallel when you are going to connect the grounds together anyway?????? I don't get it. Besides which, it's nearly freakin' impossible to isolate the cases from the grounds in the long run anyway, because of those cards grounded to their backplates through the 0v to the case, which the PSUs are screwed to.. . .. Well You could insulate the PSUs I guess, but I want a damn ground somewhere, I'm not leaving all the grounds floating. If something grounds I want it grounded through ground, not my freakin' motherboard.
So was that some stupid "abundance of caution" thing or do you really have to isolate the case grounds and how and why is it different to tying the output grounds together?????
Road Warrior
stool
stool
Senior Member
Albany, NY
Just remember that the Procooling article only involves AT PSUs. It was cautioned by Hoot some while back to not try that method with ATX.
mark
Scottsdale, Arizona
I have two questions..
I have dual PSUs currently.
I've been running them for over 6 months.
My second PSU is a 300w that runs an 86w peltier, and a bunch of case fans..
I used speedy3d's way seen here.
My first question is..
Do I need to have some kind of load (like 1 Amp) on my second powersupply on the +5v line to have it produce it's maximum Amperage or Voltage on the +12v line?
(I have heard a people say this)
If you have a multimeter, and can test this, that would be cool.
My second question...
I have seen a few dual PSU guides that have the Gray(powergood) {pin7} line and a Black(ground)line connected.
Here is the article
http://www.commongrounds-pc.com/Articles/dualpsu.html
This guide also has you connect the Gray(powergood) line and a Black(ground)line.
Here is the article
even here has the powerok line grounded..
http://www.burningissues.net/how_to/power/theory.htm
I am wondering if this is really needed.
Please shed some light on these things.
thanks,
mark
mujgy
This only apply's to AT power supplies. ATX supplies run two seperate voltage regulators for the 12v line and the 5v/3.3v. except for the antec TP series which have three regulators.
Since87
Indiana
Road Warrior
You don't have to isolate the grounds in the parallel case. There may be some advantage to picking the right place to tie the grounds together. You do want to try to tie the grounds together at only one point. Otherwise you can have what's called a ground loop which can cause weird effects like 60Hz hum on your speakers. A ground loop could possibly even result in instability in your system, but it's not going to damage anything.
The serial case is another story. You are risking significant damage if you do not know what you are doing.
sendatooli
you guys are terrific!
you guys are terrific! i was on my way over here to ask this very question figuring it hadn't been dealt with before. silly me, not only is it dealt with it is sticky!
anyways, the articles posted herein actually made me decide NOT to do this! my main psu in the machine i was going to do it to has a 550 watt.
i have a nice house and a family. i cannot afford a fire!
now i know if done right a fire is unlikely. i also have a decent knowledge of electronics. the diagrams are very straight foward.
however, anything that can go wrong will. this could prove dangerous even if done "right".
i did not mean to spoil the party. i am just glad i read the fine print that allowed me to make my decision.
thank you,
sendatooli.
wildfrogman
Sitting at my computer playing UT2004.
So, what would the results be on two delta 300 watt atx psu's that have 245 watts combined on the 3.3 and 5v if they were combined in parallel to the motherboard so in theory you have 490 watts combined? What exactly could say go wrong even if all is wired right and grounded and such...possibly each ps not responding the same and giving slightly different power?
The Overclocker
Milton Keynes, UK
(rases hand)
as the problem is not the 12v line - usally the 5v line which i shared with the 3.3v line, why not seperate the 3.3 and 5v lines so one powersupply is power the 3.3v line and the other is powersing the5v line, as these are usally (not laways - the antec trupower ones done) powered one the same line, they should be able to delive 2x the power
Crazy Jayhawk
Hutchinson, KS
Re: Dual PSU placement
tripwire said:
I have wired the PSU correctly... and got it all working with a switch to turn it on and off. But, now the delema is placement! Where do I place this damned extra PSU. Even with my rather large SX830 Antec case, it doesn't really accomadte the extra PSU.
http://www.antec-inc.com/en_wkstion.html
You could mount it in the bottom front, underneath the hard drives. You'd just need a place for the cord to go through the case.
bldegle2
Floyd, VA
Dual PS's
here is some additional info.
i modded a second PS and did some extensive wire removal, the P4 connector, the single extra weird plugin, and the whole Mainboard wireloom.
now i have a slick second PS with only powerlegs and some new LED fan connectors coming out, along with the green and black wires for connection to first PS, all under red acrylic covers.
couple of things that will make your experience easy, first, two sets of two wires go to the mainboard plug, a set of orange and set of black, ID those first, cut them back into the PS, and connect them back together (yes, you have to do this), black to black, orange to orange, then cut all of the other wires in the main loom and the other two i mentioned. no need to insulate the ends if you use an acrylic cover and they are cut short enough, if you reuse the metal cover, the cut ends should be covered for saftey sake.
and one other tidbit of info, as long as you have a grounded wiring system in your house (takes three prong plugins, not just two), then you need only to connect the green wires together to get the suckers to fire together once all put back together. the additional black wire is unneccessary, but it doesn't hurt to connect them if one so desires.
since this is all going in a see through acrylic case, i plan on shortening the outgoing powerlegs (gotta be the easiest part of the whole operation)so the wire clutter of a present day box setups is a thing of the past.
hit me with an email if you have questions.
baldy:cool:
Dhamali
South Jersey
Broken Link ???
The link to the CommonGrounds articles are not working. Can you tell me where can I find them ?
I searched that site for "dual psu" but came up empty..
D
stool
stool
Senior Member
Albany, NY
I have eliminated the Common Grounds links, as they are no longer functional.
