D
Deleted member 156785
Guest
I've built myself a sweet mining rig but I'm finding it near impossible to cool using fans alone. I would also like the option of overclocking. I'm powering the system with an EVGA 1300W Supernova G2. I'm not interested in water cooling the CPU, since it generally won't be doing much, though I may add it in later. Here's my part list so far:
2 x EK Radeon HD 7990 SE VGA Liquid Cooling Block - Nickel + Acetal (EK-FC7990 SE - Acetal+Nickel)
1 x XSPC Dual 5.25" Bay Reservoir - Laing D5 / MCP655 w/ Blue LED Light - Clear / Silver / Black
1 x Alphacool VPP655 Variable Speed Pump w/ RPM Monitoring - Single Edition
1 x EK Terminal Block - Dual Parallel 3-Slot - Black Acetal (EK-FC Terminal DUAL Parallel 3-Slot)
1 x Alphacool NexXxoS Monsta Quad 120mm Radiator - 80mm Thick!!
6 x XSPC 1/2" x 3/4" Compression Fittings with G1/4" Threads
1 x PrimoChill PrimoFlex Advanced LRT 1/2in.ID x 3/4in.OD Tubing- Crystal Clear (10ft pack)
I already have a bunch high flow/pressure fans 120mm fans. Anything I'm missing? Is the radiator sufficient for two 7990s (technically four GPUs)?
