Angry said:
Actualy ALL Socket A Athlons are tbirds....
they even made 700mhz ones....
The only difference would be that all 950 and below Tbirds had Aluminum interconnects but 1ghz and up have copper. Obvously the copper ones overclocker better..
You are correct all socket A Athlons are T-BIRDS and some of the later slot A's were as well. I have a socket A 650 T-BIRD probably intended for the OEM market, it is a week 22 year 2000 AFEA core that never could do much better than 850MHz.
It has been generally accepted that the T-BIRDS fabricated in Dresden Germany used copper interconnects and were better candidates for overclocking, while the early Austin Texas chips used aluminum. It is further believed that an easy way to determine where the CPU was fabricated was to look at the dye used on the core. Most accept that the Dresden chips were the "BLUE" cores while the Austin chips used green. Most report that all DURONS were "GREEN" cores with aluminum interconnects.
This is a moot point now since I believe that all of the later CPU's use copper.
Back to the original question.
Provided the 850's are socket A, not slot A, they should work, there are no slot A dual proccessor motherboards.
Although not "officially" supported, the T-BIRD/DURONs will supposedly work in a dual proccessor board albeit without the SSE and additional instrucitons of the XPs.
As far as motherboard choice, you are limited as to what's available, a couple from TYAN, one from ASUS and maybe a few others. I just put a TYAN S2460 together and can tell you that the performance options on this board are quite limited. I will try SoftFSB or some such program but expect no/limited help from TYAN in this regard. I understand that the ASUS board is better in the overclocking options available. Expect the upper tier TYAN and ASUS boards to start in the mid $200 range and go up from there, The TYAN S2460 is readily available for less than $200. If you're brave and looking to save a few bucks, a "refurbished" TYAN S2460 is available from New Egg for $129. I got one and it included nothing but the motherboard, no manual, cables, software etc.
For an on-going comparison of two particular MP boards, check out his thread;
http://forum.oc-forums.com/vb/showthread.php?threadid=71811
I hope this helps.
Good Luck!
