- Jan 15, 2001
I know it might seem a bit redundant, but what the heck.
Would running two low GPH water pumps yield any benefit over one higher rated water pump? For one thing I can see the benefit of having a backup in case of a failure, but I was also thinking that maybe a dual pump system would yield "truer" flow rates?
Perhaps, placing one pump before the radiator and one after the radiator? (Since most of the convolutions are in the radiator) Would the second pump take up the slack of the first pump? Or would the flowrate remain pretty much constant?
A lot of questions, I know. However, I'm thinking of building a "failsafe" water cooled rig. I'm more or less trying to see if there are any real negatives associated with such a contraption.
Thank You for your time.
