- Jan 26, 2003
- Land of 10,000 Lakes
Well I have had this system for a little while. It consists of:
2x Celeron 500's
Abit BP6
3x 128MB PC100 Ram (currently)
10GB Maxtor HD
250W Sparkle PS (Voltages seem stable)
48x CDRW
Anyway on to the problem. I have been having problems with it locking up. I can get into windows, but when I do anything, it would lock up. At first I thought that maybe the processors were overheating. I reapplied the thermal paste, and was getting load temps of like 33C. So I dont think that they are overheating.
Then I got to thinking of Ram. I started running memtest on my 3x 256MB sicks of Kingston. Sure enough, they were failing at 97MB into them. A clean install of Win2k3 used about 94mb, so when I open anything, it was hitting the failing addresses. So I swapped out the ram for the above listed. I then ran memtest overnight, and it went all night long. So I figured that I solved the Ram issue.
I booted up the computer, and it booted and I could open stuff now. I decided just for the heck of it, to run Prime95. It ran all day today with no errors, so I figured that solved my problem. Now, when I go to install my programs (AV, CDRW SW, etc) I can install a few programs, then it locks up. It is totally random as to when it locks up. I can't figure it out. I checked the Caps on the board (this board was known for bad caps), they seem to be alright. So I decide to run Prime95 again, it runs without a hitch. WTF, why does memtest and prime95 run, but it locks up. Any Ideas?? BTW, it's not overclocked either.
2x Celeron 500's
Abit BP6
10GB Maxtor HD
48x CDRW
