Hi.
I'm trying to o/c a duron 800 on a MSI K7T Turbo MOBO, but there are some problems:
When removing the j17 jumper to set the fsb to 133Mhz the system won't post, even with multiplier set to 5. I found out that the duron default multiplier is set to 8 and that the K7T turbo uses this at the first instant of the boot which would add up to 8*133=1064. To lower the default multiplier to 7.5 I closed one of the L6 bridges. The problem is, with this closed the system won't post at ANY fsb setting. If I open the bridge again the system boots fine.
Also I can't get the system to post with any fsb setting above 115Mhz, and I can't get the system to post with the duron above 950Mhz with any fsb setting. I read that there might be a post-problem with the K7T Turbo, but that's all I know about it.
The rest of my system: 256Mb 133Mhz cas 3, geforce 256 ddr. I have the latest MSI beta bios update.
Do you guys have any ideas?
