- Jun 20, 2001
I am a newbie in overclocking....Hope you guys can ans my question.
My computer is newly brought, with AMD Duron 800Mhz.... I would like to overclock to to about 1Ghz, but the Duron processor, seems can't allow me to do so, I have checked the temperature of CPU, it is 50'C at normal speed(800Mhz) after opened about 1hr, then i try to overclock it to 900Mhz , opened abt 1Hr, is around 54'C, but the system is still stable, then i try 1Ghz, it can't open the computer at all, so i release it to around 920Mhz, it is ok, but the CPU temp is around 57-58'C....so I think there is a problem, acturally i have put the high quality CPU cooler, but then the temp seems still doesn't give any changes at all.........so you man think wht should i do??>.<
