- Dec 17, 2000
- Seattle, Wa
Howdy, virtual friends and neighbors.
I'll have a Duron 850 soon, with an Epox 8KTA3, or more likely, an Iwill KK266 under it.
I really want an UN-overclocked box for a change of pace.
Running a box without any temp monitoring appeals to me.
With this in mind, I'm asking for your opinions of two HSF's. I'll have 100 cfm of case volume throughput. I don't expect to run a cool-ish Duron with 30 cfm throughput!
I have a old PEP-66 that can be relieved of its four feet. Choice of Delta 38 or YSTech 27 cfm 60 mm fan. Obviously, I'd rather not listen to a Delta--been there done...
As the PEP-66 isn't really designed for Socket A use, I'm somewhat reluctant to use it. My quandary: The PAL-6035 is a wuss, compared to a PEP-66. I'm thinking that a 27 cfm 60mm fan on top of it won't cut the mustard.
Unfortunately, I read at Millisec.com-- that the 60mm to 80mm fandapter that Millisec sells(a la HighSpeed PC) isn't PEP-66, and by extension, PAL-6035 compatible.
After more close shaves than I want to admit recently, I just don't want to mess with any GlobalWin Socket A HS. I wrecked a Slocket while in/uninstalling a FOP-38 recently. Worse, after installing a FOP-"92mm" last week, I saw immediate shutdown temps--I doubt that a Duron/T-Bird would have survived!
Does anyone know if the 60mm to 80mm fandapters sold by Overclocker's Hideout will fit a PAL-6035? Or if HighSpeed PC's fandapters fit on PAL-6035's?
I'd like to avoid the expense and weight of the imported 60 to 80mm fandapters that Plycon sells---however, if that's my only option for a PAL-6035...
Jeez, this is a complicated post. SBT!
