DVD PLAYBACK ERROR
GERRY136
indiana
about an hor ago i installed a new dvd player.
its a Hitachi 16x48 from Gateway so its completely compatible with my Gateway.
when i hit play button nothin happens when using the player that came with the dvd drive.
the screen just sits there but with no movie.
when i tried to use the ATI DVD playback, i hit the play button and get this error:
dvd playback did not start due to one of these reasons:
1. sound device is in use or not installed.
2. video overlay not available.
3. not enough video memory.
well what does no. 2 mean cause i know it cant be 1 or 3.
thanx
I don't think you need a hardware overlay just to play a DVD. I would check for conflicts and reinstall the drivers for the dvd. which software player are you using to play DVDs.
well, i tried using my new ati radeon which is supposed to have great dvd playback but i get the errors above.
then i try to use Cineplayer which came with the Hitachi dvd drive and i get the sound coming from the dvd but no picture.
1-Uninstall everything.
2-Reinstall the dvdrom drivers. Reboot.
3-Then reinstall the radeon drivers. Reboot.
4-Install Windvd or Powerdvd if you have them, otherwise you're stuck with their software...
5- (see 1-4) The order is important here.
GERRY136 (Jun 28, 2001 11:56 a.m.):
ok bro ill doit.
where do i get that software u mentioned?
thanx
Afraid they're all oem bundled software, else you have to go to cyberlink's website for powerdvd (windvd I have no idea who sells). Someone here might have an extra copy you could download, dunno (I don't).
thanx Pinky i finally got her goin and man what a pretty picture from that dvd .
ill check out cyberlink for that trial version of powerdvd.
thanx again bro!
GERRY136 (Jun 29, 2001 12:14 a.m.):
thanx again bro!
:) Awesome, another satisfied member, that makes 1,034,963,923 problems served!!
