DVD sound is choppy
amanojyaku
houston, texas
i am trying to play the matrix reloaded on my computer and the sound is choppy. can yall please give me all of the possibilities of what it could be.
redduc900
Inactive Moderator
Portland, OR
First, a few questions for you...
1. Which OS are you running...if a MS OS, have you installed all the latest critical updates?
2. What model MB...latest BIOS revision?
3. Make and model of sound card?
4. Sound card driver verson?
5. Intel chipset driver version, and Intel App Accelerator installed?
6. Version of DirectX installed?
7. DVD make and model?
8. Have you tried playing the movie at default clock...and if so, what were the results? :)
a12bc3
San Fransisco, CA
On-board sound?
If so you can try to get new drivers or put a small heatsink on the southbridge.
BTW your SP-94 is only cooling to 49*?!? My stock HSF gets up to 53* @ 3.0Ghz. Just as an FYI to check to make sure everything is copacetic.
