Hi guy's . I have put a peltier on my cpu and i thought i had the condensation prob under control , I have first sprayed the components with a light coating of non conductive stuff .Then i have sealead the socket 370 with silicone and also filled up the gap in the midle with silicone and closed cell foam. i have closed cell foam all around the cpu and the pelt .
Now i remember i din,t use dyelectric grease for the socket holes !! Does any of you have experience with this and knows if i made a BIG mistake or if i can leave it like this??? It is so litlle air that is in the
socket cpu pinholes that i have doubts about the importance , but this being my first pelt project i would like to know for sure !!!! Thanks for your help.!
btw What can i use for a replacement of dyelectric grease?? will vaseline do the job?
